As above its piss easy. Just be carefull you dont roll it whilst doing it though.....![]()
Its very simple, as you say, unscrew current one, unplug brake light and washer hose, plug them into new spoiler, screw new spoiler into place, job done.
Where abouts in S.Wales are you? I am probably coming down that way this weekend and could maybe drop in and give you a hand.
Theres two screws at each side and two in the centre, unscrew these and it just clips off, unclip the brakelight wire and the washer jet just pulls off, then they just need repositioned onto the new spoiler, clip the brake light wire on first, then the washer jet pipe and place it on the car, give it a wack near the centre so it clips in again then just screw it up again.
Dead easy and takes 5 minutes maximum. Don't need to cut anything
I will lietrally be driving through Carmarthern on Satuday. lol
http://www.cliosport.net/forum/showthread.php?240464-Clio-mk2ph1-Double-optic-(sports)-lights-conversion-guide for your lights bud
And I would suggest going out later on when its a bit darker and check the brake light, reverse against a wall or something.
When I fitted mine, although it was plugged in, it didn't work but just unscrewed the spoiler, gave it a little twist and screwed it back down and it worked again
