Front suspension top nut loose.
MRBILLYUK
Car  FF Jeden Osiem Dwa
I had a new OS track rod end fitted the other day at a local garage . Today I noticed the top nut and suspension top mount were loose . I tightened it up quickly with a 21mm socket but it wanted to spin a bit , so I'm not convinced it's gonna be tight enough . Do I need to use an Allen key and a Swan neck spanner to tighten it as much as possible ? Is there actually a torque setting for this nut ?
Rather than take it back to the garage for 30 seconds work , if that's all it is, I'll do it myself if it's thats simple .
Any help would be much appreciated :smile:
