GDI 4 Pot 172 Kit
  Tweaked Leon Cupra R
which kit? lol
does the i.6 16v not have slightly lasger discs to the 1.2/1.4's?
Andy_Clio said:
which kit? lol
The hubs are the same so it doesn't matter.
The Mk2 phase 1 1.6 16V used the 259mm dikst the other models used the 239mm disk all Mk2 2 none Rs car s use the 259mm disk.
EVOgone
  Pink Cup Racer
Andy GDI said:
will be doing a group buy on these if there is the interest..
will be approx £550
Andy thats a big discount.......group buy - 40%..
I would offer the Brembo / AP option...with the same discount. But i bet the margin's not there..
Anyways 4 pot are for posers..can i have some AP's..
  Focus ST
Wouldn't mind seeing the quote for Brembo as well as the others.
Maybe tempted!!!!!! :approve:
  GDI Demo 182, Rsi Spider
plus vat...
  EK9 + Mfactory gearing..
shouldnt be to hard, any news on the pads? also as i said is it as a 'whole kit' eg if you already have brembo discs & ss hoses (pads if they fit) basically if its pos you just want the calipers & brackets? or should i step away from the crack pipe as they say lol
  Focus ST
Step away from the crack pipe. I've read that post a couple of times and I'm not quite sure what your askin??
How about a re-post??? May I recommend the use of the full stop key...
Gweebs, what i am asking is this & il try to make it simple. the kit contains: ss hoses, brembo discs, pads, wilwood calipers & mounting brackets. if you already have hoses, discs & pads is the cost reduced? (as i would be buying stuff i already have..whats the point in that) ta Fred ;-)
lines are "just" too short.... they do fit... but stretch a little on full lock... lines are not expensive for the pair of fronts.. £25 ish
as fred says, pads are different...
  E92 M3 Monte Carlo
FredYozzasport said:
what reason??
i was purely commenting on how that kit is nothing new, its been around ages, i don't see what all the fuss is about??
just because its not new dont mean it cant be advertised,just seems a bit petty knocking other peoples products,
wouldnt mind some info on a kit for the 1.4 16v if anyone can pm me the details, anyone got it on there website?
  Hondata'd EP3 Type R
what are hi specs like?
I want 4 pots with MASSIVE 2 piece discs (330mm) (just to look good TBH, its on a 1.2 ;))
I think they look pretty good and are resonably priced. Any bad reviews on them?
  Clio 197
FINALLY someone's done it.
I was looking into wilwoods myself at one point, but the disc thickness was a problem.
How did you get round that issue Andy?
  Clio 197
I remember looking for them (Edde will vouch for me), and I had issues finding ones that would fit std discs.
I gave up in the end! :S
Yep we had trouble finding a suitable set then again knowing the company these arn't the same calipers as we could find at the time.
