Heads up....Genuine Renault Rear Brake Discs (Including Bearings & ABS Rings) Ebay
Trader Rating - 83.3%
10   2   0
  Honda & VW
Re: Heads up....Genuine Renault Rear Brake Discs (Including Bearings & ABS Rings) Eb
Good deal indeed, whack this up in the Brakes/suspension section.
Trader Rating - 100%
1   0   0
  Looking for 182
I was told about 4k miles ago that my rear discs were on their way out. However the garage that told me this I do not trust at all.
How can I tell if my discs need changing?
Trader Rating - 86.4%
19   3   0
  330i. E30 Touring.
With the rears, it's almost a certainty that the bearings will wear out/get funked before the discs. Normally due to over/under tightening of the hub nut.
To check, jack up, and with the wheel on rock the wheel side to side. If there's play, they need swapping.
2   0   0
Exactly what happened to me and the car failed it's MOT.
All got sorted in the end though
