HELP!! Exhaust Q?
Car  Weeman sucks ****
Noticed a knocking over small/large bumps and thought it was spring related but found out it's my exhaust! One of the mounts for the back box has snapped.
Trouble is I have a long commute and don't know anywhere where I work to get it checked.
I guess what I'm asking is will it f**k up the rest of the system if I limp home with it??
Any help would be great.
Its not going to help but you should be ok if its only the one which has snapped. Anyway you could zip tie it up?
^ yep, same i had industrial cable ties. with heat tape of them, worked fine, mine wasn't broken was just basically there to pull the BB up.
Thankfully a guy here at work used a garage 2 mins away (which I didn't know about) and it's up on the ramps as we speak waiting for some welding action...phew.
I think you will continue to have problems with that supersprint. I suggest sending it to me and i will pop a £50 cheque in the post..!
I'm honered you think it's a supersprint. It's actually a prospeed mate. Easier to find and cheaper;)
Arrrgghh Post a pic... I guess it a new one as part of the Group buy. Did you get the single cut in bumper one using the 182 surround ??
If so what do you think of it ?
