If your blower will only operate on certain speeds, its highly likely that your blower matrix
has gone.  This is a matrix of resistors that decide how fast the blower motor runs.  The
matrix is protected by a themal fuse, which blows if the resistors get too hot (which they occassionally
so, especially on older cars).  You have 2 options -
1.  Replace the matrix (dealer only part, i think about £25)
2.  Replace the thermal fuse (40p from maplins)
Obviously, you cant solder the new thermal fuse in, so youll have to remove the old one
and recrimp the new one in.
The matrix is in the engine compartment, just below the drivers wiper arm (behind the wiper
motor).  Its not too bad to get at, but make sure you disconnect the battery before
poking around in there, as it will give you a nasty bite, if youre unlucky.
You wont be able to tell if the fuse has blown, as its a solid component between the spring
resistors, just trust me that its blown.
If you can use an ohmeter, you can test it.  If anyone needs anymore info, let me know
If your blower will only operate on certain speeds, its highly likely that your blower matrix has gone.  This is a matrix of resistors that decide how fast the blower motor runs.  The matrix is protected by a themal fuse, which blows if the resistors get too hot (which they occassionally
Obviously, you cant solder the new thermal fuse in, so youll have to remove the old one and recrimp the new one in.
The matrix is in the engine compartment, just below the drivers wiper arm (behind the wiper motor).  Its not too bad to get at, but make sure you disconnect the battery before poking around in there, as it will give you a nasty bite, if youre unlucky.
You wont be able to tell if the fuse has blown, as its a solid component between the springresistors, just trust me that its blown.
