Help im trying to take my front bumper off but failing
Car  172 gone :( 197 now :)
I took the bolts out of the top of the headlights,
the two bolts under the wheel arches,
i've undone the bolts securing the plastic to the plate underneath the car
and i've removed all the torx screws underneath the bottom lip.
It still seems to be attatched behind the bottom outer corners of the headlamps though?
if i remember right theres 1 bolt and a clip under the arch, then 2 clips on the upper grill, u gotta undo the wheel arch linen from the bumper and undo the screws/bolts on the plastic underneath the front end. Then u need to pull down and out where the bumper joins the wheel arches(its cliped to the arches there).
U have to give it a nice tug, feels like it will break but it just snaps away. Aslong as you have undone all the bolts obviously.
There are two underneath, two on each corner and then the two clips holding the grill in. Once done, pull outwards and forwards to unclip each side :)
I think it must just bewhere its clipped to the arches then as i'd undone all the bolts but it felt as if it would snap if i pulled any harder. I'll have another go i've put all the bolts back in now though lol
