How not to detail.
welshname
A friend posted this on another forum and it did amuse me, whether you lot will appreciate it or not (as you don't know the guy) I don't know.
did some general maintainance/ cleaning, now having studied the show/shine threads on here I felt i had a fair understanding of the correct paint friendly proceedures needed to such a task.
So i took the Bootlid which was filthy into the warmth of the house in order to maintain a constant working temperature.
removed the spoiler to reveal
Then using the 'head and shoulders' I degreased and conditioned the paintwork. I've heard of paintwork conditioning before and never known much about it, it really does add lovely life and bounce.
Nicely cleaned
Having understood the two bucket method, i didn't have two buckets so i moved onto the next best thing
Check out the perfect colour match of the cars respray
Next Stage was the engine cover which was equally as dirty
this time Radox was employed to 'soak away the tension using sage and sea minerals'
applied using the tip and pour method
for a lovely finish
I can see how this stuff can take so long now.
welshname
Part 2
Done some more today
Im going to do this out of order as my Favourite is one of the first stages so i'll put that last
After the initial wash down stages which will be revelaed later,
I used a 'Microfibre Sponge' to remove any larger surface contaminant
as i understand the Microfibre it is the hooks and loops that do the work
some larger contaminant had been harsh on my sponge
this was a fresh sponge aswell, truely gutted
Now obviously the next stage is the clay stage
i used specific lube that is resistant to sun
and applied directly to the panel
I went and got a fresh piece of clay
and methodically worked the surface
just check the filth it picked up - this was just from one section of the bonnet
welshname
Part 3
So went onto the Polish stage, my polish is a mutli purpose use but definately get a shine on glass.
it had gone slightly hard though so this was gently prepared before use
this was worked in and rinsed off to remove any remaining dust
and the waxing stage started
i used a specific colour matched wax
and gently warmed the wax
with the waxing done i wanted to seal and protect the finish
applied by hand
To achieve a pleasing result
right, time to address my favourite stage, Snow foam and mopping.
Snow foam to remove the initial surface contaminate
application, lovely coverage
and 'Mopping',not entirely sure on the correct mopping processes but i think i pretty much nailed it.
anyway, thats been my detailing, hope you like.
I was pleased with the results
I LOL'd at "check how much filth it picked up" when he's just standing with a lump of dirt in his hand, superb.
