5 liters from memeory stops the trip 4.5 for the red light or the other way round i forgetMine goes to ---- from 50 or 60 miles. Once you have below X amount of litres (probably 7 or 8) of fuel you have left. If you drive as you have been driving it will be accurate, and you'll still have a bit of fuel left in the lines also, however why test it when you can take 5 minutes and fill up.
If i cruise i get 46 from my cup.
If drive it hard i to work and back over the tank i still manage around 38
chekced this by brimming the car and doing the maths manually and the trip is pretty close!
when it goes to ---- it means one gallon left
I thought Clios had 50L tanks.
No it definitely does it when you have 1 Gallon left too.
It will always goes from a number to ---- when it hits the same figure as your MPG
Thought so, which puts the 1 gallon left theory in the bin as I've never put more than 42L in mine. And I've seen the light on before.
The light comes on before the display goes to ---
I've put over 48 litres in mine.
I can vouch for this, fuel light came on ad the display went to ---- about 5 miles later.Yes it does, really I've seen it! I'll take a pic next time.
Its not by much, maybe 5 miles but it happens.
No it doesn't, light goes on and miles left goes to ----
Otherwise idiots would try the range left, break down then have a go at Renault.
Why would you want to take you tank that low anyway?! Best to leave a bit at the bottom to stop the crap being sucked up...
I think if it slops to one side going up hills etc it can trigger the light/sensor before the --- comes on iirc.
Lol, thats a load of rubbish as any crap in the tank is constantly been mixed around while driving...
