Hi all I have at last started my project racer. my spec list is below I will post pictures as soon as I can as parts have finally started to arrive.
ENGINE.
300M steel crank
300M steel rods
300M steel mains caps
Tri metal engine bearing set
TK mains studs
TK head studs
I S Clairingdon nuts through out
Structural spec alloy engine brace
Omega coated custom high compression pistons
CNC port flow machined cylinder head
Custom designed Hollow billet steel cams
Inconel valves
Supertec conical titanium valve springs
Birrilium valve seats
Custom made 55mm tapper single throttle bodies
Custom made inlet manifold
Custom made carbon fibre air box
Stainless steel exhaust manifold with carbon fibre silencers
5 bar fuel pressure regulator
4 Pico 12 point injectors
4 Pico twin point injectors
TRANSMISSION
Sadev ST82 6 speed box
140mm twin plate clutch
300M 2 kilo flywheel
TMP falppy paddle gear change kit
ELECTRONICS
Race technologies DL1 data logger and dash kit
Magneti Marelli ECU
BODY WORK
Custom carbon fibre wide body kit
carbon fibre rear wing
WHEELS
Rays 10 x 17 rims
Dunlop slicks
This is the vast majority of the spec and I hope to have the whole car finished by the end of the year. If I can work out how to do it I will get some pics up of the parts that have arrived and the engine builds.
Hope you like it
			ENGINE.
300M steel crank
300M steel rods
TK mains studs
TK head studs
Inconel valves
TRANSMISSION
ELECTRONICS
Magneti Marelli ECU
BODY WORK
WHEELS
Rays 10 x 17 rims
Dunlop slicks
Hope you like it
