As long as you have all the tools and parts you'll able to rebuild it nice and quick.
Is 1degree negative camber on the rear going to be enough for you? Most race cars/track cars are running more like 3 on the rear! We could all have too much for all I know I havnt driven mine with that amount on but iirc the burpspeed race car had a similar amount.
Its probably a +1 deg shim. remember there is some camber in the axle as stock. You'd have to ask Tony or Fred what ours is running now as weve just re-done itIs 1degree negative camber on the rear going to be enough for you? Most race cars/track cars are running more like 3 on the rear! We could all have too much for all I know I havnt driven mine with that amount on but iirc the burpspeed race car had a similar amount.
Have you thought about your lighting yet? I run 2 Seat Supacopa's in Britcar and other endurance championships and the lightpods with PIAA set up on each car work out about £2.5/£3k alone. When your running for about 3 hours constantly at code 60 in Silverstones pea soup fog at 2am then you have all the time in the world to regret a poor decision on lighting!! Also whats your plans for the fuel tank? You can fit a huge ATL tank but Brit car regs only allow you to fill a maximum of 100 litres per stop.
Car is looking great by the way keep up the good work but unfortunatly I know what its going to come back looking like after 24hrs!!!!! Made a start on stripping ours last week after the Dubai 24hr in January and one does not have a straight pannel on the entire car...
Oh an another thing before you get too far in building it back up, invest in some lockwire and do just about every nut on the suspension for peace of mind for the whole 24hrs![]()
Why run 195/50 15" when you can fit 205/50 15" without a problem?
15s are better for track mate. Car handles better on them IMO. Cheaper Tyres are a bonus![]()
Iceman
From April 2011 you now need a Nat A license to race in Britcar Production.
You need to check if this new MSA rule will be different for the 24 Hour.........but I doubt it
You may end up spending big money on a car and have no race....unless you are already going for 6 race signatures on a Nat B license prior to the 24 hour.
16's are better for brake cooling in endurance 15's are better for handling and cheaper, another suck and see I think.
Brake cooling difference would be minimal really. I presume you'll be doing cooling ducts?
I suspect wheel design makes a huge difference too, wonder if wheel manufacturers have details on individual rims...
PS
I have Been quoted £700 to paint the interior white. Do you think that a lot? I have no idea myself, this is from the motorsports company near Custom cages. Car might be back with me Thursday by the way if I don't opt for that paint.
