Icemans Britcar Endurance project 182
Jamie86
  RS175,595,205gti,172
Great result well done!
Which part of the gearbox mount did you break the "stud" type part as I did the same going over the crest of "the Mountain" at Cadwell park..
Also which mount was it as I have some Vibratechnics ones to fit but not so sure now..
  BMW Z4
Video looks great! so much to watch :) shame the track gps thing in the bottom left is abit out.
also that clio right at the start, what was he playing at!
Yeh I have raised an issue with the track map to support. Just glad the video worked, now I can tweak it and make it better. As for the Clio I think he was on a roll after overtaking me and forgot the corner LOL. I was lucky to drive through it all without incident.
The engine mounts are vibrotechnics and it was the hanging gearbox one that snapped the bolt that goes through it.
Jamie86
Ah like I said the same thing I managed to do, but mine was on standard 120k+ mounts all round..
I'm guessing you probably have but did you chang the bottom gearbox mount as mine was very worn and I think that certainly didn't help matters..
  BMW Z4
The bottom one was old and has done 80k miles. I shall change them all now and add an extra dogbone and extra engine mount too for good measure.
Jamie86
Sounds like sensible option.
I noticed that Tony, limiter seemed ideal just touching it as you were getting onto th brakes..
Jamie86
I keep thinking of raising mine as keep touching the limiter on "avon rise" but mine's no racecar!
Jamie86
That's what I was planning on using tbh..
Also meant to ask but what is the 205 running? Holds it's own quite well in a straight line with you.. and certainly got some interesting braking balance!
Jamie86
Yeah consistency beat him in the end!
I did watch the whole video as well, I'm jealous of your camera setup :eek:
  BMW Z4
Yeh a lof of people have said that. It will be better next time out too. Gonna move the forward camera next to the screen to help with its focus and make the image sharper, and also move the rear camera central too.
Got the box out now ready for the new box with gripper and shorter final drive. They will all get a shock at Cadwell :) Oh and to top it off I have a nail in my front tyre LOL. So lucky to finish. Ordered a recon rack and saxo power steering pump today with the reservoir built into it.
LOTS to do and ten weeks to do it all.
Some pics for you all...
My new third camera
Fitted a nice carbon sheet for the DL1 to sit on
Tony having a snooze
And again :)
Some of the brake dust off the 1155's
This fell out of the calipers
Having my arches rolled
Fred the man
My mate Darren who drives the S3
My first trophy
The fast Pug guys
Even mum put in an appearance
And Frieda Pinto my fiance
The Bubble and Kick team
My busted mount
And my pin falling out
205's
My little splitter
My new M3 mirrors
Nail :(
Snapped bolt
Mark
  Clio
Pics aren't working for me, your engaged to freida pinto?! as in the actress? or have i just made myself look like a bit of a dick lol
  TrackCar & F30 330d
Some good pictures there, the trophy looks like quite a good size!
Have you moved house now? Looks like a different garage!
Why have you not got a sun strip too?
Used to have a set fitted to the Caterham and they wobble like mad and are too small for the clio IMO :( I need to sort out a mirror as my cage slightly blocks the vision
I'm gonna try 16's with 225's FTW
Good on you mate for trying something different :) Interested to see how you get on with the 16's
Great photo's from Silverstone and once again great result!
  Lionel Richie
na not needed, the engine HAS to have some movement, you'll just break stuff (as you already have) if you try to reduce its movement too much, we snapped all sorts on the cup cars, but they were abused engines etc, the rods fell out the bottom end most of the time LOL
  BMW Z4
Ok im toying with the idea of refitting the ABS system to see what the difference is in feel. Tony do you use ABS on yours? Does the ABS pump just take a live power feed? I guess it needs nothing from the ECU as it has its own computer in it yes?
Mark
