The photo where you have the headlamps off bud.@RMDavis Which photo bud?
@Martin. That i dont know tbh. I have these ones:
http://www.motamec.com/motamec-spri...ector-shock-bag-black-16-406mm-long-pair.html
That would've made sense to do. 😂😂No i didnt, but i did clean the shut before refitting it. I also fed it in through the side and slid it in that way, rather than from the top.
I'm going to have to get some bulbs now, my output is nothing like that and as I won't be driving in daylight for a few months they might be a good buy!
Bulb linkys please Mark. £25 is a steal!Not bad for all of them for under £25 delivered!
Just been out to my sunstrip and its bubbled up a little on the passenger side, and is basically not even stuck down on that side. Fab. Was perfect a week ago!
@182_steve The bracket has always been tinted black. I thought this too but its always like this, its the shadow that makes it look solid black.
Also, regarding the wheel, you can fit a resistor but luckily my friend Alex has Clip and turned out the light for me :smile:
The boss and steering wheel came with the car when i bought it but momo, omp or oreca like this one is fits all aftermarket wheels.
First and only time I had the bumper off I lost an arch liner the next day! I think I've only got a couple of screws in it now too.
@182_steve Im sure @MrBlonde has done it via the resistor. Alex has clip so it was a no brainer for me to get it done that way.
As for the bosses, my personal preference is Momo. Not sure why as there all the same but i like the brand. The OMP one a has a different rubber sleeve. Either way they all fit aftermarket wheels as the holes are all the same.
Yes i did see you message him. He'll sort you out ok. Tbh bud, once its fitted its hard to see through the bracket and it does look solid black from the seating position. 6 button ones work well as you dont need to change the stalk for a ph1 one with horn. I already had one fitted so seems silly to remove it. I personally prefer the 4 button anyway as it looks like less is going on, if you get what i mean? Either way, its definitely something to look into. If you need any advice etc regarding the wheel, boss or bracket, just holla at me!
Luckily the clock was £10 so nice and easy to fix, plus the new clock bezel was sprayed tonight and im happier with this one so it was money well spent!
Yep my was ok with just putting a resistor in,didnt work at first but then i redone it & just made sure it had good connections with the resistor then put insulated tape over. @182_steve
Bulbs ordered. You should be on commission!
Loving the updates - one of my favourite cars on here.
Car is looking great, job looks good too![]()
Good man, thanks for that, may take you up on the advise offerI totally agree about the 4 button bracket, it does look much cleaner but as I don't have the Ph1 stalk, I won't bother getting one, will just go for the 6 button variant. Maybe I can pretend all the buttons are for ejector seat and machine guns etc 😂 joking aside, should look good! I get that with the Momo, will have a look on Demon Tweeks. Don't want a cheapie off eBay.
Thanks for that :up: so with the resistor, no lights on or any other issues?
Got a link to the bulb for the ash tray? [emoji1317][emoji817]
