Thanks for your input matt, appreciate it.
Right information as follows, I'll share all of it, including the obvious stuff.
Firstly the unit fits on in the following manner:
F4R from a Clio, converted for single seater use (virtually the same as the FR2.0)
You can clearly see the different aux setup on this side on image of a different engine with the same kit fitted:
Obviously this has implications for other aux units, such as the PAS, but not something I can't solve.
The unit uses a revised aux drive pulley, gearing down to achieve the correct RPM for the pump (I assume - I will confirm this with Paul on Monday)
A clearer image of this replacement setup can be found on this segment of Product Assembly diagrams Paul has kindly provided me with last week:
Fitment wise for a stock engine there are some parts that need to be removed:
Bracket on the gearbox side - IIRC it holds a loom / PAS pipe.
One of the aux mounting points outside of the water-pump housing is also conflicting the position of the aux drive point:
The end plate is a straight fit, providing the lower mounting holes the sump pan:
General shot of the unit:
The kits internals:
It has a single output positioned (once in the car) on the front nearside of the engine:
The sump pan itself is actually very simple in design: elevated section for the trays / baffles, with a canal running around it's outer edge (around 12mm deep):
The windage trays are simple sheet stainless, with countersunk hex head bolts securing them in place, this makes them simple to replace / redesign if as matt has pointed out they are not suitable for the hatch application.
Bbviously to fit the unit you have to remove the standard oil pump, chain assembly and the windage tray.
There are three outstanding issues (excluding actual oil management):
1. Standard gearbox bell housing does not fit onto the end of the sump pan, so will require a vertical adapter block (not a problem)
2. Does the oil pump clear the subframe at the front of the engine? (tbc)
3. Plumbing - luckily we are only based around the corner from Think Autmotive - so building a Mocal based kit for the tank / plumbing is not a problem.
I'm going to give Paul a ring on Monday and run some more questions past him. Matt I will probably discuss it in more depth with yourself when I see you next week to collect my kit.
I'm more than aware that this is potentially overkill, however:
1) I am aware from my short time so far being involved in the championship of at least two instances where Clio Cups have suffered oil based issues, so although as already pointed out a well designed baffle system would do the job; this will too.
2) The kit provides extra sump clearance - which in the long run beyond ground / kerb clearance; provides the option of lowering the engine.
3) I like interesting project based work so: :rasp:
