Knocking/clicking noise 172
  Black 172
Knocking noise on a 172
It's been doing this for a while. When not moving and turning steering wheel it clicks and knocks like mad. And wen moving less than 20mph it does it as well just not as bad or that could be coz of road noise (confused)
The inner joint was knackered on drivers side so had a recon shaft in and slightly better.
The cv joint on passenger had no grease when I bought so knackered that shaft. Had it reconed and solved that problem.
It's had powerflex bushes all round on front.
But run out of ideas. I did hit a kerb a while ago (drivers side). So had new wishbone, steering arm (scrappy job) and subframe :-( but have just run out of ideas. Help please
thanks
sounds as though there could be lots of possibilities, but check that the steering rack mounting bushes are v tight as well as, loose, they can make a 'cracking' noise, esp. whilst stationary
  Renault Megane R26
I had a simular problem, check the shock mounts under the bonnet, Mine came up really high had replaced and knocking has gone.
J@Y
  Clio 182 and CBR 600
Can anyone tell me where the steering rack mounting bushes are please? Are these where it mounts to the subframe?
