little bit help
Car  corsa b
hey am new but got a question i need answerin for a mate - how hard or easy is it to change an electric window mech on a '03 clio and is there any tutoial to it anywhere on hear?! a garage quoted him £200 - would like to help him out a little - gota run will post properly tomorra,
Cheers guys and gals,
Jon
Nah its piss easy
Pull off the door card, you'll need a T30 torx and a T20
Then unbolt the motor and runner, 10mm socket
Then unclip it from the window, install the new one, iirc you have to do a bit of wiring, 2 wires. check to make sure its wired the right war round!!
then sling it all back together, takes about half hour tops.
is that as easy as that - i thought it would be but i wernt sure, so say get a new mech for what, £60 or so then follow the steps you have said there and hay presto my mate leky window is fixed?!
Jon
oh but what is a t30 or t20?! will i need them or can i use something else?!
Torx 20/30 these gay little heads on screws/bolts the french use. Pick them up from halfords cheap.
You sure its the motor jonny? Whats wrong with it cables frayed? jammed up/down?
Jon
There torrx bolt sizes you cna somtimes use screwdrivers but don't bother go to a motorplace and buy a selection only a few quid much better of with them.
its not mine its a mate, he tuk it to the place he bought it (they quoted him £200) but the said the mech was nackered, i can get a full mech for £60ish so if its easy enough to change i'll do it for him.
to whoever it was that asked where i live i live just outside surham in the north east
cheers,
Jon
is there anyone with any pics by any chance just if i am going to get one of these for my mate i want to get the right one and fit it proply!!
cheers,
Jon
