2003 Clio 172
It looks like I'm going to have to pull it apart and check the timing againI didn't realise there was a window on the bellhousing and timing marks there. I had been using that Renault manual PDF 3286a and there was no mention of it there. So there are four numbered timing marks on the block and I line the grove on the flywheel up with mark number '0' ?
When you say check map at idle, you mean the manifold air pressure ? Mine is reading around 500mB or so at idle but hopefully I can find out what the precise figure needs to be.
Again, mega thanks for all your help here... really appreciate it.
Very interested in seeing how you get on Davy........mine is idling IDENTICALLY to yours.
I think mine is belt related (changed last year) but I am unable to fix this myself unlike you. Would be keen to see if your work remedies the idle as I was about to start buying injectors etc.
Keep us posted
J
