metalic/ratteling sound in 197
Car  clio 197, mazda rx7
my 197 has been making a funny noise for a while now , well constant for the past month and a half. when i hit 6k rpm in every gear also in neutral.
so took it to renault as i still have warrently and they had the car for 2 days and got back to me and told me it was from behind the glovebox, apparently there was a loose bracket, which sounded odd to me :S. any ways they gave it back and i was driving home and no noise :D. in the morning on the way to work started makng the noise again :mad:.
so now they say they gona have it for around 3-6 days and there gona take the whole dash out and road test it like that to find the noise.
anyone else had this problem (197 or normal clio 3)
thanks drifter197
Does the noise get more high pitched as the revs rise? Coz mine does this as soon as it comes on cam. The garage thought it was a faulty engine mount at first but its still there so i gotta get it booked in again. Its so annoying!
I dont get anything in neutral tho.
I was thinking it was a fecked rev dial?
Exhaust issue IIRC
nope defo not ehaust.
its from behind the dash (thats where it sounds like its coming from), well inside the car. i thought it could be a gearbox issue bu they reassured me it wasnt probs to much of a big job and they cant be bothered.
and no the noise dont get any higher it stays the same.
its just really (x10) pissing me off now
mine mae the noise, it was the exhaust and ren did a simple adjustment.
oh lol, they told me it defo wouldnt be engine/exhaust related.
they said could be a gearbox problem (like 2.5% chance) or dash (97.5%).
tbh i couldnt careless as long as it gets sorted
'you will find that you will get a metallic ringing which sounds like a baffle gone on your exhaust - this is not the case - it is simply the harmonics of the engine, you will hear the same noise on the car if you run it without the exhaust system on at all.'
Apparently from that site its quite a common thing...
I know how annoying rattles can be. On my 182 everytime I hit the 5k revs 'kick' I get this constant rattle from behind the dash somewhere!! I took the dash off myself to see if I could fine it and test drove it with a mate that way to try find it and I couldnt!!
Could you not reach up behind the glovebox have a wiggle of whatever is behind there?? Could be worth a go..
Hope you get it sorted..
it went to renault and they have already removed the glovebox and test drivin it like that and it was sorted, its going to them on friday so hopefully it will get sorted
