Chips Nova Vs Overboosts Clio needs to happen would be epic.
Great car, love the engineering that's gone into it.
430! f**king madness. Epic.
Wasn't this the one at FCS inside?
Was very impressed by the car at fcs when I was chattin to you.
Wow, thanks for all the positive comments. As everyone is probably aware of now, the car made the journey to French Car show at Donington, and spent the day inside the paddock suite. It drove hitch free, although it's prompted me to look into some suspension tweaks. The car has always been planned as a road car, and possibly a daily driver. Track days and drag strip use are just added bonuses ;-)
I modified the front suspension arm balljoint position to increase castor, which has had a huge effect on the cars straight line stability at speed. I'm still convinced the wishbone bushes are moving around under power and cornering, so currently i'm fitteing some spherical bearings into the wishbones. Hopefully this will be sorted for the RTOC frog of the pod day in september. Will post some pics up of the progress.
Cheers again guys
His car is a work of art compared to mine. Far better.
Altgough apparently he did copy my rear suspension tweaks so at least my old shed was useful for something. Lol.
epic skills!
if we ever cross paths, i'm buying you a pint
Hello m8 ! how's things ? Good to meet u at FCS.
Thanks for the praise, I can't believe mine is far better than your's, mine looks tatty to me and in need of serious tidying up lol.
And yeah, like i said to you at FCS, i think the rear suspension tweaks are a big key to keeping the rear geometry in check. ;-)
on the 1st test drive vid is that the sound of the turbo waste gate chattering>?
Definately, but extra caster on the front is certainly key too, especially to braking stability, mine was utterly horrible under braking when it had very little caster as there is no front end weight.
chip said:Ive altered the wishbones now, I was looking at cup ones to begin with which add a little more caster but decided to modify my own instead.
It gives 35mm more caster done like I have done it, compared to the standard ph1 wishbone, which is about double the cup changes.
However, you could actually add another 15mm to that if you accepted slightly losing some track, by elongating the inner hole backwards instead of outwards but I didnt want the extra caster enough to compromise a few mm of track width to get it.
This is how I did it:
Drilled a new outer hole, and elongated the existing inner one slightly, and trial fitted the balljoint both there and in the original place so I could take some measurements.
Then I plug welded the original outer hole (TBH you really dont need to im sure, there was quite a bit of meat between the holes but I can so I did)
Then I used a power file to make sure there were no highpoints that the balljoint might touch and not sit flat
Then I gave it a quick paint just to stop it rusting
Then while I was stood around feeling quite pleased with myself with how it had turned out (Im no fabricator TBH, just do bits and pieces) Mike from MWM who is staying with us this weekend proceeded to do just as neat a job (better if anything) of the other one in half the time, damn him and his expert welding skills, lol
How the end result looks:
Handling feels a lot more sure footed now, its very stable under braking, and obviously I can now run less static camber which is good for straight line grip.
Very pleased with the results although ive got lots of rubbing to sort out.
Did it the same way m8, putting the new hole in exactly the same place, although i did replate up the arm where the balljoint flange wasn't touching it, if that makes any sense !?
Side view looks like the wheel is too far forward, same as yours.
on a side note, I presume the car has to be re-tracked once the caster is added?
Ahh Mr Blocky, bet its awesome at handbrake turns :quiet:
:rasp:
Not really TBH, mine seemed to be in good contact at both mounting holes.
Got any pics showing what you mean?
Yeah they look broken with that much caster.
The VW boys will probably start doing it soon just for the look, lol
