Mk1 F4R/172'd Track Car Project [Year 3 - Engine and Chassis Rebuild]
  clio 1.8 16v, civic vti
Re: Mk1 172 Hybrid Track Car Project
Where from if you dont mind me asking? and would i be right in assuming they dont post? as im a billion miles away from you lol, i got mine sent from merlin motorsport at castle combe
They do post, dependant on weight. It would have been £30 to post that order (49kg)...but a lower quantity would be less to post at a guess. Il PM you the details now!
Oh also, they have branches all over the country. Might be one near you!
yeah right, the only thing near me is the ginsters factory!
Cheers;)
Greeny.
  440i + 182
wow I love this project/car, you always do things properly and that video is awesome :)
Made a start over the past few days with the tube. Im aiming to get the screen out, all bars profiled and ready to do one lot of welding on everything within the next few weeks at the latest.
As said a few days ago I picked up the additional CDS, the bulk of it went off to Whiteley at the weekend as you may have seen in his thread. The list of cage additions/modifications is currently:
- Remove Lower Door Bars and Replace with an X
- Horizontal Bar Behind Seats (Welded at the same height as the lower door bar and lower rear stays).
- Remove Current Seat Bars and Replace with 45mm Tube inc Brackets for Mounting Sidemounts To.
- Extend Cage (From the upper door bar joint) through to the Front Turrets/Struts.
- Diagonal Bar from the Turret/Strut Bar (Back into the car to join at the same height as the joint for the lower door bar)
So I've been moving forward with the door bars over the past few days. The length of the full door bar is 44", and I wanted the joint in the middle...so obviously the 'crossover' had to be at 22".
Chopped two 23" lengths off so I had enough to play with...
Then spent a bit of time profiling the ends, and after having done this once before it didnt take too long...
I did those in the dark so I was pretty sure that they would need trimming/adjusting so they both sat properly on the bar. The short lower door bars had to be removed to be able to do this though...
To:
The remaining metal/weld still needs to be tidied up properly but Il wait until I have the proper sanding tools/disks to do it, not in the way now anyway. The top one wasnt too far off to start with...
Then tried the lower one...
As you can see its not far off at all, took a bit of adjusting to get it to that, and im still not 100% happy with it, the lower bars angle is ever so slightly off, lol. The lower one needs a tiny bit more adjusting but not much, will get there.
Ive nearly finished the bar behind the seats too, but needs finishing off. Will update when I've got that and some more done.
Also got a few other bits off Whiteley when he came down the other day, a new Thermostat Housing for one. As my current one has a hole drilled with the Mk1 Coolant Temprature Sensor fitted, which we now know is no longer required so I wanted to get rid of it to tidy it up a bit!
And a set of Gaz Adjustable Rear Shocks, as my current ones are not adjustable. At least it will give me something to play with over this year. Ive sent them off to Gaz for a new set of seals and refurb (which was suprisingly cheap), so I should have them back sometime in the next few weeks.
More soon!
Looking good, the X door bars always look purposeful...,strange question, but how you find getting in and out? as i wanted X bars on my escort but i couldnt physically get through the hole that was left, and thats a much bigger opening than the clio has....,maybe im just a gorilla
Dicky Belly
  Whichever has fuel
Jordan is about 15 and 5ft 2. Must weigh about 7 stone soaking wet.
He'll fit in anything! lol. ;)
Its something that I honestly have not checked, LOL. The steering wheel will have to be removable though, or it wont be possible to get in/out...
5ft 11', 10st Il have you know!
  Mk1 F4R
I struggle getting in your car now and look like an idiot doing it, wounder wot id be like getting in it with the x bars.
Maybe its coz im tarded lol :eek:
This is looking good! There better be some 'Riggy' bits on this cage ;) you not gone for the plastic piping then? Was thinking drain pipe maybe... can get all the bends you need form B&Q lol
Will keep an eye out as I need some Cage inspiration :)
Also, snap off steering wheel might have to be bought....
Tunst
  Focus ST225, Focus E
Thats never a good sign, what you got planned?
Hah, nothing really. I got it the lot silly cheap from someone, and its something ive been meaning to learn for AGES.
Ive done bits before, but will be perfect for me to use it to tack all the new cage bars into place ready for a mate to weld them up properly for me. Then hopefully carry on using it and learn some more about it!
Tunst
welding kinda easy once u get used to it, burning urself is the most annoying part :eek:
Hot metal/sparks FTL
Yeah, ive done some TIG welding before, but never had the cash to buy a decent enough TIG Welder. So just went with MIG this time as a starting point!
Stripped it down before and cleaned up all the feed mech, started having a play and ran out of wire... Just need to pick up some fresh tips and a new reel then should be good to go :)
  Mk1 F4R
I thought it was awesome for the price when we went to pick it up and we got a free towel too :rasp:
Tunst
The wire seems to run out fast, or mine does :dapprove:
Tunst
i have a reel of both just incase but iv been doing alot of welding recently, i still dont get why people want sheds M.O.T'd when they know the dam thing is rotten -.-'
Just been and picked up a new reel of wire, couple of tips and a new liner for the torch wire, so tomorrow probably.
Tunst
The tips wear away quite quickly for some reason lol :S
Id practice tacking all the bars in place etc, and on some scrap and then do the cage yourself, much more satifying to do it yourself.
Im using 5kg reels and they last a fair amount of time, and im welding quite alot, very easy when you get the hang of it, and still on the same tip as i got with the welder years ago:)
a crap one lol, its a clarke 130 'turbo' so nothing special at all, but it was cheap at a vat free day at machine mart, fair few years old now, only got 1 wheel left on it, and has DAVE written on it as i made the mistake of leaving it in work one night :rolleyes:
Well as you can see this one is only a 130amp'er too!
Replaced the liner and put the fresh wire in not so long ago, made a massive difference to the smoothness of the feed, just spent a few hours playing around...far easier to get it to do what you want once you've got it setup right and no worn parts.
wilky19
  Leon FR 184
soo want a welder have been thinking about getting one and doing some welding class at the local college.
don't mind me asking how much that set you back
