.com/jordisgay
As mentioned above, ive been putting together a 5th mount for the front of the engine the past day or two.
This is what a R5 GTX mount looks like when purchased from renault, the rubber is in the bag...
The rubber alone is 47 quid from Renault! Anyway, decided to see how much the rubber would be from the local factors, £6. So I set about making my own bracket...Used some thin aluminium to get the shape/dimensions/angles right, as there is quite a few angles involved...
Once I was happy with that, I got some 6mm steel, bent to the angle I wanted. I then used my template to replicate it on the steel...After doing that, I cut a piece of spare roll-cage tubing up, to strengthen the mount, and welded it in place. I decided to add it to stop any 'flex' in the metal mount...
This is the rubber from the motor factors...
Gave it a quick coat of hammerite...
Once dry, mounted the rubber to it...
As you may have noticed, once of the holes is elongated/slotted...After marking where the hole was on my ph2 bottom end (in the car) and drilling it, the hole on my spare bottom end was in a slightly different place oddly.....so I made it big enough to counteract any errors in the marking....fits ok now anyway...
This is the hole on the subframe where it mounts....
Then fitted it...
Spot on. No engine movement at all now really, alot better :evil:
Foxy what website hosts your blog as im trying to find one thats actually half decent that requires little maintenance but i am failing miserably?
Nice work on those mounts, i would have definitely had one but im fitting the volvo engine so not sure it would fit.
Everytime I read this thread, I get more and more frustrated at how stupid I feel! Can you see if these mounts fit the Mk2's... Less engine movement would be yum!
Might be an engine rebuild too now![]()
Just drove the car and had a major constant rubbing noise that changed with revs. Severe lack of power and a dodgy smell from outside too. Managed to get it home fine, but i've no idea what it is. Popped bonnet off and everything looks normal, just a bit of a burning smell. Oil level is still on max too.
Cambelt idler maybe? Who knows. Doesnt sound like an internals sort of noise, sounds like a belt I think :dapprove:
Too bad Mk2s dont have the hole in the subframe (or not that I know of) as the design started from mine which was made for the F4R block :boring:
Bad times.... youll have it done before i get mine done![]()
Had a look this morning to see if they would fit and they will, but in order for it to work you have to run the cup setup and then just drill a hole in the subframe,![]()
