Re: Mk1 172 Hybrid Track Car Project
Tried some other relays earlier with no joy, just the same....
Anyway this is what I have now tried:
Swapped crank sensor, which did not fix it.
Removed all conduit from ECU wiring, checked all the joints one by one, all fine.
Checked the ECU plug, seems all fine.
Tried the different relays as said, no change.
Then the starter motor stopped working, could just hear the solenoid firing, but not turning. So turned the engine over by hand, was fine and seemed to 'free' the motor, still wouldnt start.
Removed starter motor, tested it seperately. Works fine. Then connected it to the cars wiring in the engine bay but loose, works fine.
Fitted back to the car, attempted to start again, turns over as normal now, still no start though.
Sat around scratching head for 10 mins, went to start....and it fired up! Left it idling for 5 mins, then turned off. Went to start it again straight away, started up again!
After another few mins, turned it off.....left it a few mins, went to start it...nothing again
RSTuner was also playing up, not connecting and stuff at times. When I did manage to get it connected, it had a fault in the memory of 'Ignition Constant Feed' or something....checked all the ECU power wires, all seem fine.
Only thing left for me to try is remove all my extended wires, and replace them all with fresh runs of cable, not cable cut from old looms....hopefully that might sort it
