recently my 172 has had some reconstructive surgery. As most of you know the 172 inlet is one of the bigest restrictions on the car, so we have bolted a 197 inlet manifold to my car. Paul from Autoparis in Melbourne, has done all the work, so far we have used groupN cat cams, extensively modified head to suit manifold. the head is bolted back on and the car now idles and is currently being tuned.
before the work was carried out the 172 had a BMC CDA, and a devil cat back exhaust system. (dynoed at 94kw atw)
we are hoping for a base off 200hp at the fly. which should be good for about 110-115 kw at the wheels.
paul has used as many stock parts as possible to keep the costs down, including retuning the factory ecu, which means no cutting into the factory harness. we only had to extend one plug out of the whole harness.
http://www.autoparis.com.au/
