Montana's Titanium 182 diary...
Car  Clio 197
Hi all,
I returned to the CS fold after buying my Titanium 182 in early December after selling my WRX.
Initially i had wanted a FF 182 but after coming across this Titanium 182 i realised that the cup packs are only minor improvements that i could manage without.;)
Some pictures from the seller;
Managed a quick clean up in between the rain storms we have had recently, I also replaced my plates as the others were looking a bit tired - also check out how misaligned they are - as soon as i noticed that they had to come off asap!;
Picked up some new matts courtesy of my other half :-)
The first time i had it on the motorway (other than my drive home) when exiting a sliproad the engine light decided to come on. Thanks to LeeShez who read the codes for me, the code reader gave me P0420 (Cat Efficiency) which left me thinking cat / lambda issue, finger crossed but so far the light hasnt come back (1 week later).
It had the old issue with the Climate Control not working which i was fully aware of when buying it. This proved a bit of a pain on the drive home with the windows constantly steaming up.
Quickly got on the case with replacing the resistor itself after reading symptoms on here, this didnt work and after some playing about with a multimeter the motor itself was dead. Decided to source a complete motor / resistor pack and wiring loom in order to fix the issue.
So at the weekend i replaced the motor and it ran on full speed all the time so replaced the resistor pack and the climate was fully working - happy days!;)
This weekend i also gave the engine an oil & filter / sump washer change using Elf Evolution SXR 5w40, weirdly Renault only stocked 1 ltr bottles so had to buy 5, got 15% discount though which helped.
I also gave my exhaust pipes (milltek) a wire wool / autosol clean up, they have come up a bit better but not perfect - ideally i wanted to clean the inside too but after seeing the resistance it put up compared to my freezing fingers i decided to save that battle for another day!
At the moment i have no solid plans other and engine bay tidy up and a wheel refurb - planning to stick to silver i think, i enjoy the whole clean silver look. I have been thinking about lowering but don't want to ruin the ride as its quite firm at the moment (could be tired shocks though).
Been busy with a few highly jobs over the weekend:
- replaced my hazard switch as the old one was faulty
- replaced the standard washer jets for the fine sprays ones from ciyore - much better!
- refitted my head unit properly as before it wasn't sitting quite right
And the biggest job of the weekend was exhaust related, I have a full milltek cat back on and I was aware of a slight blow and an annoying rattle, I checked the exhaust and realised I had water dropping from both ends of the cat and the back box - I set about changing the centre mount for the revised Renault item
I planned to replace the rest mounts with powerflex items but as I had already identified a blow on the back box join I decided to remove the back box for a spruce up
When I removed it
After being cleaned up with autosol
Picture of my back box refitted with the stronger rear mounts
Now I have no annoying rattles and the back box sits better
Weirdly although both ends of the cat were dripping water there was no physical blow that I could feel , however that's a job for another day!
Next job is to investigate the washer bottle leak!
Spent tonight getting my alloys refurbed - whilst I had the wheels off I decided to change the brake fluid and tidy up the calipers .
When I arrived
Before
After a clean up
After a quick coat of hammerite (will be tidied up in the future)
Action shot of the alloy in the prep process
We got them masked up tonight, will be primed and sprayed tomorrow and picked up Thursday :)
The 182 feeling sorry for itself!
Looking good! I like it, any other plans?
Plan to give it a full machine polish & wax - looking forward to this because I am itching to try out my new DA :)
Need to fix a few little niggles too , like leaky washer bottle and slight boot leak
I cant wait to this is also, only had my car a few months and the weather has been awful for it !!
I know, no chance of doing it outside with the weather as it is at the moment. I will be popping back down to my brothers unit (above) at some point to give it a good going over.
Just realised how rubbish the photos above are - i uploaded off my phone last night. Will get much better pictures once its been washed/iron x/clayed/machine polished & hand waxed ;)
Got my wheels back late last night , just applied some poor boys wheel sealant and tool a quick pic - filthy car , clean wheels.
