Clio 1.2 16V
Hi all. Took my 2005 1.2 16V Clio to get tested today and it failed on the emissions:
"Exhaust emissions carbon monoxide content after 2nd fast idle excessive (2.92) [7.3.D.3]"
"Exhaust emissions lambda reading after 2nd fast idle outside specified limits (0.91) [7.3.D.3]"
The results were:
Engine temp: warm
Fast idle test...
Engine speed - 2500-3000rpm -- Not checked
CO - Max 0.20% - 2.92% - FAIL
HC - Max 200ppm - 122ppm - PASS
Lambda - 0.97 to 1.03 - 0.91- FAIL
Car has 116,000 miles, and was driven about 0.5 miles to test centre.
The car has been loosing a little bit of power when putting the accelerator down and sometimes chugs to get up to speed. Sometimes also hard to start. Changed coil pack and plugs about 2 months ago where it somewhat rectified the problem but has now gone back to its usual. Last night the Engine Management Light came on and has stayed illuminated (solid orange - not flashing).
Any help/advice would be appreciated. I am trying to get it into a garage to get it plugged in but its late on in the evening now and the ones i've been able to contact have 2 weeks waiting list.
Thanks all!
The results were:
Engine temp: warm
Fast idle test...
Thanks all!
