MOT questions
Car  clio 182 black /gold
Hi my car have just been they it has passed but several advisory items.
I was wondering if they are covered by warrenty.
Nearside inner rear brake pad wearing thin, only 1
Offside steering rack gaiter deteriorated
Nearside rear shock asorber has a light misting of oil.
Screw / bolt missing engine cover
Cable wearing through nearside front to shock asorber area
Slight corrosion exhuast
Why would only 1 pad wear?
Inner pad will be a sticking piston i think, if it was the sliders it would be the outside pad. might be wrong though
Common fault some have had them covered under warranty so you should be fine.
cheap fix
Common fault lol it'll fall off soon!
Nearside inner rear brake pad wearing thin, only 1 possible warranty, depends on the cause really.
Offside steering rack gaiter deteriorated I would say definitely warranty
Nearside rear shock asorber has a light misting of oil. Warranty
Screw / bolt missing engine cover A few pence from Renault, not sure why it'd be on the MOT though? :S
Cable wearing through nearside front to shock asorber area Can you elaborate Lee?
Slight corrosion exhuast Not under warranty, wear and tear.
Why would only 1 pad wear? Needs looking into further...
If it has been MOT'd doesn't that mean the warranty will have expired anyway?
The cable is bonnet catch. The brakes are caliper sticking. 28K and none of the others are worn bar one. I got the warrenty done a month early due to the car reputation
What is the bonnet cable rubbing on? I would suggest that it just needs repositioning, nothing more.
If the calipers are knackered I would be talking to Renault for definite!
Is your car still under warranty?
Yes under till 21st March. They said bring it back next Thursday. They also said pads not under warrenty, but hey if all worn even then yes.
Mine just passed this morning with "Nearside rear shock asorber has a light misting of oil" as a comment after. Was certain it was going to fail for some reason, so had some good luck for once :)
