My Bedford Trackday Video......
Lee
  BMW M2C
Nice one Steve.
Once again, it goes to show that Porsche owners love to use their cars properly.
EVOgone
  Pink Cup Racer
FredYozzasport said:
very nice Steve, you could've gone so much faster through 2 of those corners
Vids were from the morning session the afternoon was a lot better......! There was lots to be had in the braking too but the DS2500 were fading ask Edde...!!!! Back to ds3000 for proper track action. Was my first time at bedford but will be doing it again soon..!
  Fiat Coupe 20v turbo
Watched the first 10mins pretty good ....looks like an airfield..is it a track?
  Lionel Richie
the right hander onto the start finish straight is flat out according to Yoz, but i'm not 100% convinced (you'll end up in Kettering!)
and that left hander before the stupid right into 180deg left into back straight is flat out if you have the balls for it (car becomes a bit "weaveie" under braking)
EVOgone
  Pink Cup Racer
First ones a slight lift you can go flat but you go wide (no real advantage) the second corner IS flat.:D
dk
  911 GTS Cab
i take both of those flat myself.
manji said:
No brake fade? Stock breaks?
DS2500's stock disk though they failed very quickly though.
Was a good day I want to go back to Donnigton though next.
I'm flat out thoguh that bend on the start finish though shame I'm only doing 25mph though flat out.
EVOgone
  Pink Cup Racer
omar said:
Nice vid...
A bit bouncy those sportlines eh? Is your damping still on 3/4 ?
Its the issue with using progressive springs on the track...! Great for the road though. Shock set at 3.4,did try them will max but to bouncy...!
KW's or Billies mmmmmm
Killed the brakes...fade (hard pedal no stoppin)..! DS3000 again for the serious track action.
