I doubt the oil pressure gauge would react quick enough, I see where you are coming from with regards the rally, but it may just be a certain set of circumstances not duplicate from rally to rally even the same rally.
The PEC rods I put in Porkie's engine I checked for ovality with the con rod bolts torqued correctly, they were all found to be perfect, although if I had my way I would have preferred a set of Arrows, but not until any lubrication problems are sorted.
I have used many of China's finest con rods (same as PEC) in many a turbo Vauxhall/OPEL XE/LET/ZLET/LEH/LER engine without problems, again I would have preferred Arrow rods.
Some recent data logged information given to me from a circuit racing Clio showed oil pressure to drop below 1 bar during racing, under acceleration, deceleration and cornering both directions, this backed up some information I was given by a team who ran these cars for F2 rallying, they did use a baffled sump, as dry sump was not allowed due regulations.
I am part way through sorting a dry sump system for the Clio with a fabricated oil pan.
Some very nice parts you have purchased, I hope you prove me wrong and that nothing happens to you new engine.
Steve
