Omex ECU and the CPS Wires
Car  ITB'd 172 POPTART
Omex reads the Crank Position as well as the Renault when spliced into it (2 Wires).1. What is the use for the renault ECU connection? (Dash Data?)2. Is it needed?3. What are the implicationsI have created my own standalone IGN CCT with the OMEX wired up to a custom fuse relay setup.So with the REN ECU disconnected in its entirity and just the omex running the engine etc is this an ok move?Thanks/Craig
Omex reads the Crank Position as well as the Renault when spliced into it (2 Wires).1. What is the use for the renault ECU connection? (Dash Data?)2. Is it needed?3. What are the implications?I have created my own standalone IGN CCT with the OMEX wired up to a custom fuse relay setup.So with the REN ECU disconnected in its entirity and just the omex running the engine etc is this an ok move?Thanks/Craig
i dont know why its formating all in one sentence but i can fix it. Sorry its hard too read
