On/off radio logic on 2003 Clio Dynam 1.2 16v
Hi,
Can anyone tell me how you change the setting on the cd/radio to turn on and off with ignition? It was fine until I blew the fuse in the cigarette lighter which seems to have reset the radio/cd to factory settings meaning it turns itself off every 20 mins and stays on after the ignition is switched off and keys removed. I'm told it's simply a matter of pressing the right sequence of buttons but I can't find it in the manual anywhere!
have you replaced the fuse? it should reset its self. the radia has 2 fuses, one for the radio and one for the radio and lighter (accessories), if the lighter fuse has poped it disconncts the "accessory" circuit of the ignition. or something to that effect.
