Another attempted start today, but no joy.
Motronic 1.3 swap is complete and I believe to be correct.
We identified that the fuel pump relay is knackered, once the relay is bridged the fuel pump can be clearly heard, so a new relay is needed.
Possibly the same for the ECU relay (or DME as it seems to be called?) but I'm not certain that it's had it.
Ultimately, I'm getting a good cranking, fuel seems okay, I'm just not getting any spark. Coil is getting power, ECU is getting power, I'm pretty sure all the ground straps are okay. I've tried a HT lead straight off the coil, and that's not sparking either, so it's not the dizzy or the HT leads.
Possible culprit might be:
There doesn't seem to be a plug for the ICV? There's a 3 pin block, but it's been wired into the oil level sender (by someone before I owned the loom). Now this seems okay to me, as the FL oil level sender has a 3 pin connector on it, doesn't it?
I'm not sure if no plug in the ICV would cause the engine not to spark, I'd suggest not?
I've tried swapping the CPS and the CID connectors over, no joy. I tried putting the TPS block on the ICV, and that had no joy either.
Long and short of it is that I have no idea, and I'm now putting it out there as a call for help. If anyone who has done this before/is competent with auto electrics is free this weekend/any night in the week or any time in the near future, I'd be massively grateful if they could spend some time with me trying to sort it. My next option is paying for an auto electrician, which I'd really rather not do. That said, I'll be happy to pay someone if they're coming over to try and help, I don't expect anyone to just give up their time for nothing.
Anyway yeah, that's where I'm at for the time being
