Nocould the inner arms make a racket without any notable play by hand?
Yes had that loose noise when going over pot holes, drain covers replaced the driveshaft with a re manufactured one from Renault to fix.Also, could the n/s CV (outer) or inner tree (inside gearbox) crate a noise over cobbled surfaces?
Worth removing as they can wear through.Outer ARB bushes are all original so are tired but I am just not convinced its them, i cannot find any slack in them.
Rodger that................this evenings activity is now booked.
Never really gave the engine bay fuse box wiring the "go-over" it deserved though, especially the white plug so that is the first port of call
Cheers guys
J
I've attached the list of pins for the 90 pin connector.
I don't think so @Louis
What about this is as a Servisol alternative @STEVE.M ?
https://www.screwfix.com/p/wd-40-sp...VPc9L6GaJK0VqzdEOewaAkbDEALw_wcB&gclsrc=aw.ds
Thanks for that James.....that is the ecu connector or the white one that gets minging?
