Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
If I were you go to renault for the handbrake cable. My local, and usually reliable, motor factors supplied two different cables when mine went and neither fitted the car. Easy job once the correct cable was in hand.
After speaking to those in the know I changed both cables even though only one of mine was broken. Each side is different but they cost about the same. Think I paid about £50 for the pair from my local Renault $tealer. The invoice was knocking about but the wife has filed it so may take some finding. If I can find it will give you the part no's.
If you give them your registration number they should find the part no's on their system.
you HAVE to change both cables now, there's a tech note about it, Renault released a moddified part that is slightly longer/stronger (and forgot to tell everyone!)
