Rear caliper options
ripp
  182 FFAT
Would like to rebuild my rear calipers but been reading that they're a pain to put back together.
Remember seeing a 1*2 with smth like 197 rear calipers (I think as he also had brembo fronts) and was curious if this is easily doable or not.
Or any other compatible caliper instead of the old 80's bendix stuff.
Cheers!
Mk3 non sport rear hubs and discs with 197 calipers. I would do this if I could get it all for cheap but am just going to rebuild the calipers for now
ripp
  182 FFAT
Yeah this is the first thought - rebuild the caliper- but always had the impression that it's a poor design compared to - say the 197 rear caliper.
But I may be wrong and the std unit refurbished should be good?
I'm having poor brake performance and want to sort the calipers and fluid before dealing with abs module /or master cylinder stuff
DomP182
  ph1 172, Arctic182
I've just done my 172 rears, easy and like @jamesBsaid leave the handbrake seals alone except for the covering boot
ripp
  182 FFAT
All the ones I've rebuilt have pulled 160kg each on the MOT rollers, which is about as good as you can get.
What is the piston diameter? I can find 30 or 32mm seals but which is the one?
Thx!
DomP182
  ph1 172, Arctic182
Yep get the Bigg Red kit, FYI they are loads cheaper on eBay than on their site
