rear stub axle's help and suspension breaking 172 cup
Car  Clio 172 cup, 106 rallye
hi all,
Im lost on clio's and need some adivce,
I got hit the other day in the rear 1/4 a glancing blow that sent me in to a spin. Anyway, had a propper look today with a mate and found the stub axle is bent (and pos wheel bearing gone), my question is........ Where do I get one from???
Also within 6 months of owning this 172 cup the front spring has snapped and a rear shocker has broken, its only done 59k. No track usage, driven hard but never been driven hard over rough ground.
Would I be best off getting a coil over set up to cure both these problems??
Thanks steve.
i got a stub axle from clio spares, see the trader section or via ebay. thier easy to fit but the bearing will probably be chuffed. they're not the greatest at the best of times.
coilovers will sort the dampers and cracked spring but it won't unbend your stub axle.
