rear wheel bearings????
  ph1 clio 172,v6,r5 turbo
ive got a early shape 172 clio.
i have just fitted 2 new rear wheel bearings and for some reason the centre nut on 1 side keeps loosing its self off.any ideas?????
i cant do the nut up really tight with the nut gun because it stops the disc from turning.there is a small metal washer behind the disc would it have something to do with that??????????
  C63 AMG, F430 & 172
rear hub nut should be 175NM
your bearing isnt pressed in right, or you have fitted the washer the wrong way round.
  C63 AMG, F430 & 172
you can see the stub axel is taperd at one end, the washer/spacer is pressed to fit this ridge.
