Renault Clio 1.4 16v 2004 Better Bite Brake Pads
Car  2004 Clio 1.4 16v
I find the Clio brakes are harder to push and dont have a very good bite to them at all, Compared to the Corsa a slight tap to brakes worked well. Im thinking i just need get used to different car.
But had mixed reviews some saying Clio brakes are like cheese against a grater and some say they great.
Any Suggestions on DECENT Pads that bite well for street use NOT racing.
Was Thinking ADL BLUEPRINT??
My Clio is 1.4 16v 2004
The standard brake system across the Clio range work very well imo , obviously if working as it should be no sticky calipers etc. When was the brake fluid last changed?
Get some decent discs and pads on there from Brembo or similar and bleed the fluid through and you'll notice a big difference
Thanks for Reply
Not sure when brake fluid changed.
Any info on changing brake fluid will be great??
Ive purchased some adl blueprint discs as they meant to be OEM equivalent spec.
Pads ive gone for is EBC Ultimax as they were decent price on ebay and good reviews.
Thanks again
