Replacing Clio 172 Engine (Project ;))
  B/G 182 + PH1 Track
Worst Renaultsport in the family this one ;)
Feel like mine to drive now carl? i will have a go when im back home.:cool:
Barron
  Turbo S,Exige,R5,182
Why didnt u change the clutch when the box was off?
Cars a peach mate!
the clutch looked fine and there was plenty of meat left on it.
should have changed it back then but ah well, live and learn :p
carl
  RB 182
Looks to be loads of life left in that clutch plate? Make sure you change the release bearing while you're there!
Barron
yes changed the release bearing. Car drives so much better, smoother gear changes :)
carl
  Ph1 Clio 172, VX220
Just found this thread as was looking for info on how to get the engine out on my ph1 172, then I realised there are a couple of you just around the corner - I'm in Newton Aycliffe. My engine died in the snow and has no compression at all, think crank pully has slipped and bent valves as belt wasn't snapped. Anyway, I'm going to swap the engine, your method seems the best way, pull the engine and box out from top as I have an engine hoist.
Have you still got the Clio? and what do you think of the Focus RS - that is one of the cars I was thinking of changing the clio for until the engine went - still might but it won't be until may now.
Really nice build, nice work.
Nick
