Teg
				The car does breath some oil.. Not sure if it a normal/healthy amount or not as I know nothing about Renault/F4R engines. I do roughly 6 or 7 track days a year so the car will benefit from fitting one. On these engines is it just a case or remove the black hose from the induction hose and fit it to a catch tank? Anything else to plumb in?Run an oil catch tank, does your car produce any blow by, check you intake. Also throw out the aircon, a/c systems place a not insignificant amount of drag on the engine, you don't need it anyway :wink:
Wouldn't mind removing the A/C as I never use it anyway... Might have to look into it to see how much work is involved.
