Black Gold 182FF
So my 182 has been steaming up. A lot. Although I can't feel any wet carpets or anything. Tonight while I was home and it was light and dry, I figured I'd check out the pollen filter (which is on record as being changed when I bought the car). It's a bit misshapen cos of the poor design (who thought that up, seriously) but it looks fairly new still, just lightly soiled (it's had 5k of use). While I was trying to put the scuttle back together, I noticed this:
From the shape of it and the fact there are clips, I'm assuming that's actually supposed to be on top of the scuttle panel? I've forced it through and it clips in nicely which makes me think that it's supposed to clip in on top but could the fact that was underneath and pushing the scuttle panel up off the windscreen be what's causing the moisture? I know there's a drain point "in the middle somewhere" but I haven't found it yet so I dunno whether it's likely to be near there and that there's been water coming through.
Also the scuttle panel is in a bit of a state, the clip on the passenger side has broken off, the middle is now lifted because that piece of plastic was underneath it, etc. I'll probably buy a new one but is there any way of sealing the bottom edge of the windscreen? Not going to be able to get a new panel until into the new year now and would rather stop any more potential water if I can just seal it somehow.
