As Porkie says, this build isnt about chasing numbers, its about managing to stay in one piece.
If we can have about 210bhp on a bit of a footballer map so we know its nice and safe, that'll do nicely, porkie is the sort of person if there was only 95 ron fuel available on site and he ran out then he'd just fill up on that and trackday it and hope its ok, lol.
Rough spec:
11.8:1 compression forged pistons and steel rods
Mild port job on the head
C&B replica cams
Inconel 2 piece supertech exhaust valves (but the join is much higher up than standard away from the heat and better transfer into the guides)
single piece supertech inlet valves
uprated valve springs
omex 600 ecu
Megane turbo injectors
AT power (far too short really but its what he had) throttle bodies
Helix organic clutch
ARP rod bolts
ARP head studs
then obviously all the normal stuff like new cambelt and new oil pump, new valves guides etc
There is the minor incovenience of my birthday this weekend so im away for a bit, but hopefully we'll start the mapping the weekend after (injectors should be in by then too which is also holding us back) with the plan being to have it ready for bedford on the 25th of feb as we know Lee will cry if it isnt!
Rough spec:
C&B replica cams
omex 600 ecu
ARP rod bolts
ARP head studs
