spark plug blew out - helicoil size ?
  Ultra 197 ex 172 Cup
Spark plug blew out, i searched the forums, can't find out what size helicoil do i need to get,
there are lots on ebay
m10, m12, m14 ?
im confused.com
will this do ?
14mm Thread insert/repair kit
Superb quality kit from Beru, repair those stripped spark plug threads! Includes thread cutting tool and a selection of thread inserts, all in a quality wooden case. Insert sizes (4 of each) supplied are 14mm x 9.5mm, 14mm x 12.7mm, 14mm x 19mm, 14mm x 17.5mm (tapered seat). Additional inserts are available to order. Supplied with instructions.​
£36.43
Add to cart​
  C63 AMG, F430 & 172
gutted this happened to fine
you need to get ALL the sworf out or the rings will die.
IMO take it to a engine shop!
mine cost £90 i think to have done
3rd plug from the right by anychance?
no 4th plug popped loose. can i get a small magnetic tool to remove any stuff inside the cylinder ?
or what if i shoved down loads of air from my air compressor, could i blow the dirt up and out from the cylinder
thanks for the help
If you have a hoover could you not get some really thin hosestick it on the end and poke it down the hole just a botchy idea lol.
  C63 AMG, F430 & 172
thanks for the help
if you take it too a machine shop they will get it out and fit the coil.
they used a micro hoover on mine
for the sake of £100
get it done at a engine shop
  172, S2000, S1 Elise
Thanks for the ideas,
I'm at my girlfriend's so unfortunately without my tools, I can't even get the engine cover off to have a look!
Forgot to say that no dash warning lights came on, if that makes any difference.
It does smell slightly of fuel under the bonnet when running, which makes me think you could be onto something with a spark plug having popped out?
If that's what it is, once I've checked, am I likely to damage it further by limping to Northwest Performance (the nearest specialist), or should I get a tow? It's only 3 miles.
