Spark plugs difficult to remove.
Car  Ph2 172, 106 Rallye
I was having a futter about at the weekend and wanted to check the state of my plugs whilst I had the upper inlet off.
The first thing I noticed was that the plug holes were half full of engine oil, there was no leaks from the rocker so I can only imagine someone poured used engine oil in there?
After I soaked most of the oil out with rags and paper towels, I tried to remove a plug and it felt as if it was going to ring the threads if I put any more pressure on them.
Is this a common problem? I'm afraid I'll wreck the threads on the head.
Can't imagine someone pouring oil down all 4 plug holes.
The rocker cover is probably leaking internally into the plug hole bore. Mine does the same on one or two.
The plugs can be quite tight, try warming the engine up first.
Good idea on warming it first. I put the socket on them and had that gut feeling that the threads were coming along with the plug.
I'll have another bash at the weekend.
Cheers.
The car has been faultless for months, I was just going to check the condition of them but it seems like it may be more hassle than it's worth.
If they give too much resistance when I try at the weekend I'll not bother trying to remove them.
Sorry to hijack thread but didn't see point of making a new one.
I too have what seems to be oil down in the ports, got this removal tool from Halfords: https://www.halfords.com/workshop-t...MIwtDH29v_4QIV0kPTCh3NsQ7pEAQYAyABEgIICvD_BwE
and these plugs from ebay: https://www.ebay.co.uk/itm/Genuine-...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
Socket fits over the new ones a treat but when I try and put on the old ones, it doesn't seem to be gripping. Is this the only size spark plug on 182's?
If so, is there a technique to it? seems a lot more complicated for me than usual spark plugs for some reason lol.
and these plugs from ebay: https://www.ebay.co.uk/itm/Genuine-New-Renault-Spark-Plug-X4-224018760R/222642576925?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
New plugs look wrong ones mate.
Got them out now, was a 16mm socket in the end meaning I got sent the wrong ones :mad:
Just ordered some more and after reading up on the horror stories, have gone for the NGK ones. Bosch supers have been removed and look a bit crusty tbf.
Yeh, deep one of course. Plugs are the recommended NGK PFR6E-10 3688 when they arrive (hopefully before Friday as I've got it in for MOT then and is currently in bits lol)
