Mini R56 JCW 211bhp
For the past few weeks I've been aware my driveshaft brace on the offside front has been loose and rattling against the block. On Friday when I was driving I started getting a knocking noise from under my feet kind of area. So I replaced the bolts in the brace with 2 normal M10 bolts and tightened up. But the knocking remains. Tried and checked a few things over the weekend and the symptoms I've found are:
*Only after the cars been driven a while (20-30mins)
*Not as loud as it was when the brace was loose
*Rhythmic "tap tap tap"
*Only on slight throttle/slight steering (Like 30mph in 4th kind of throttle. Not full lock that I've noticed but seems to happen steering left or right)
*Stops when you dip the clutch
*Was accompanied by a squeaking heard outside yesterday.
CV joint was suggested and I'm not sure as I use full lock regularly and never noticed any knocking or noises.
I'm assuming it's connected to the driveshaft as it's not near the gearbox area and engine seems unaffected.
