Greeny.
440i + 182
thats a cool little trick
mine using 1.1 to 1.4 of fuel
Mine was on 3 on idle :S
Whats the reset button? is it the same button on the end of the stalk.
this should be stickied or put in the guides section![]()
It would be good if the normal trip comp displayed mpg figures in real time like the fuel consumption in the diagnostics mode.
Its not like that forget it.huh really?? More details, mines an import, hows it done!?![]()
I have a t--- come up, is there anything i can do? Aside from pay a grease monkey to have a proper look?
Mine was showing a " t " So i pressed the reset button for the comp and it cleared it . Reran the test and the " t " had vanished . Mine was fluctuating between 0.8 and 1.1 litres and hour when idling . Anybody else tried resetting the comp . Might just have been on " old " fault stored . Would love to see more results form other people .
MrBillyUK !
If there a fault does it will show this again after one drive ?
After doing this test, will it cause any other probs...i.e get lights lit up on my dash?
I mean I just paid Renault £65 to plug it in to their computer to clear a fault and I don't want to do this test if I have to go to Renault to clear another fault that this test has/may cause....
Ive read that people checked their speedo after doing this test and found it to be 2-4 mph out....how do you check for that?
mines showing t--h...any ideas?
Stored faults
t mean an injection fault has been detected for a minimum of 4 seconds
J means a fault has been noted on the fuel gauge. It must have disconnected for longer than 100 seconds. The resistance from the fuel tank sensor needs to be between 5 and 350 Ohms.
d means an injection signal fault has been detected
h means an oil level sensor fault has been detected. Resistance from the sensor should be between 6 and 20 Ohms. Any reading over 20Ohms is an open cicuit anything under 3 is a short circuit.
If no faults are logged then dashes will show fixed dashes.
Press the reset button to clear the logged faults. Other faults arn't shown on the display.
CLICK HERE - a video of my mums doing it lol
on mine (which doesn't have a trip) as edde says press and hold the mileage/clock reset button instead. I did this the other day and found no faults, although it showed up my speedo is slightly out by 2-3mph![]()
why does your 182 not have a trip?
just done this, my serv light dosnt light up and i dont know where it says hiow much fuel im using? any ideas cheers
