so more done today, finished chopping out what i started chopping out the other day, and then tidied up a bit.... but i am sure more can come off the looms... (more of that at the end...)
Starting off with the loom left from the other day.
after speaking with chris (crispy) i knew/thought i could loose the entire door looms, so they quickly went, that removed a lot of extra wires...
i then went about removing all the excess from the looms, i removed all the unused pins (male/female) from the smaller plugs, i really struggled to remove them from the bigger plugs / big ports, how has anyone else done this / left these?
i then masking taped the looms up, i will tidy this up later on, another question though, does the interior loom need heat - shrinking or is it fine as is with zip-ties?
the three finished looms below
so the plugs i have left on the main loom (that i labelled are)
Ignition x2 (Plug and Barrel)
Dash Dials x2 (both plugs)
Indicator Stalks x2 (both Plugs)
drivers side rear loom plug
passenger side rear loom plug
drivers side footwell earth
passenger side footwell earth
Headlight dim
cigarette lighter
hazard switch
the plugs i have left on the drivers side rear loom (that i labelled are)
Drivers door sensor
Fuel Pump
Rear light cluster
rear earth
the plugs i have left on the passenger side rear loom (that i labelled are)
passenger door sensor
boot sensor
rear light cluster
central brake light
bumper number plate light
rear earth
thats all good, now the stuff i need answers for, any help massively appreciated as i need to get these right....
first off hopefully an easy question...
Do i need to keep the door and boot sensors?
next up i have a series of plugs on the various looms that i am unsure what they do, any help with these again appreciated... see descriptions and pics below...
Passenger Rear loom - Midway along - Grey Plug and Clear Plug
Passenger Rear loom - Midway along - Black Plug
Main Loom - Passenger side (i think) - Black 6-point Plug
Main Loom - Near Ignition - Purple 6-point Plug
Main Loom - Near Ignition - Black 8-point Plug
Main Loom - Drivers side - Midway along - Grey 3-point Plug
Main Loom - Centre Console - Black with Cover (OBD PORT???)
Main Loom - Centre Console - Black Female Plug
so i need answers for all the above really before i go chopping more, as mentioned any help appreciated...
