Well sorry but I've not been keeping this as up to date as I should do really :/ started a thread over on meganesport.net as well lol
Few things have happened with the car
 I've finally bought a DA polisher so had a little play with that but between family's cars needing repairs etc I've not had much time for the megane
few photos , had a play on the bonnet, came up really well !
great machine and great products , I've only used the enrich, as the restore compounds a little corse on renaults soft paint, and I haven't had time use the final but looking forward to having some time and nice weather
Also finally fitted the front discs and pads , loads happier with it although came across quite a few complications
As you can see they were very due lol, but when replacing the NS disc, I noticed that the lower hub bearing bolt was loose , this concerned me a lot, and I tightened it up, and found that the steering became very heavy , the lower bearing is fooked
 another thing to fix
At this point teddys came out the pram a lot , but have since spoke to a bloke over on megane sport , he's going to replace the bearing for me rather than replacement hubs as everyone says it needs , (£230+ vat) he's going to do them for £80 a side , he's going check the drivers side and if it needs that, then he will do that too! Top bloke
Also did a full LED upgrade on the interior , 13 501 bulbs later :O
Not the greatest pictures but gives you a idea, they are awesome, did both upper lights , did the puddle lamps , number plate bulbs (and lamps replaced with new lamps) boot and glove box
I've not got around to fitting the braided lines , and I've ordered some Titan sintofluid oil for the box
So need to get the lines on , oil in, and I've also dropped on a Baileys recirc dump valve
 full kit inc blanking plate etc £40! Over the moon so that'll be here this week
Sorry about the long post
more to come
