Was a Clio 1.8 16v
I know there is a few with turbos who come on here plus some experts so thought i might give it try:
I currently run a T3 stage 2 at 10psi with a 195 Superchip and standard injectors. Piper cams, IK, S&S xorst.
Will the superchip which is off the self work fine with the T3s power deliverly as it would be programmed for the standard T2s deliverly or will the map sensor mean itll be fueling fine though-out the revs?
Plus i plan on running 15psi with 701 biege injectors, should i have a mapped chip?
Any info appriciated.
