Custom made From a clio flange some pipes with injector bosses welded on
Or you could buy the jenvey one and weld your own injector bosses on
Ah right. Doesn't look like it on the pic so you've done a tidy job of that.Custom made From a clio flange some pipes with injector bosses welded on
It's a Honda one I've bought a f4r flange and going to chop and weld it on. Injector bosses welded into the runners or just use the other 4 that are underneath. It's got flushed trumpets
I'm in the process of building one of these, well similar in concept
Ah I see!That's not my one, just the picture I used to plan my design from
To convert a 172/182 to the 197 is a mission mate. I've done it and it's not worth the effort. That's one of the reasons I went to a 197 head/inlet combo. Plus, the 197 head is far superior to the 172/182 one.Given the R3 Maxi Evo makes 250 on the standard inlet manifold, is it not possible to swap to the mk3 manifold rather than fully fabricating from scratch? If it requires some work to fit is it not likely to be at least less work/easier?
If anyone on here is on Facebook join uk fwd drag series there is a thread going on at the moment all about plenums
Not on FB. What they saying??
Mega detailed stuff. Makes for a good read I've tried to copy the link
The Honda forums are really good for this stuff as they are light years ahead of us in the all motor side of things
I don't mean to be cheeky but I don't suppose you have any of your original measurements do you?
I won't be designing or building the inlet, but any extra input for the guys at Zisco would be a bonus. They're the chaps with the software and expertise to pull this off I'm just the middle man [emoji3]
Thanks a lot, Craig
Simple question, I'm the middle man here and it would of saved me measuring it up myself.Really??????
Can I have the measurements I personally think if they are going to design one then do not try and rip someone one off and use there info.
Steven I think you should reproduce yours as it is i think there is lots of money to be made if £700 is going to be the going rate.
I'm doing the same thing only on 197.To convert a 172/182 to the 197 is a mission mate. I've done it and it's not worth the effort. That's one of the reasons I went to a 197 head/inlet combo. Plus, the 197 head is far superior to the 172/182 one.
Surely that's going to be a very short runner length though?I'm doing the same thing only on 197.
Running some simulations in Solidworks at the moment.
Hopefully, will have the first prototype carbon inlet for my 197 in the next month.
Will have dyno tests before/after the inlet.
It will be bolt on the lower inlet manifold.
Yes it will but take into the consideration the length of the lower part of the plenum...and I'll have some "spacers" made extra so I can "play" with the lengths of the runners and see the results on the dyno/street.Surely that's going to be a very short runner length though?
I think you'll lose a fair chunk of torque mate with such short runners. Do you have any images you can post? It may help me understand your design. Don't worry I'm not out to rip it off! I'm very much sticking with the 197 inlet on mine.Yes it will but take into the consideration the length of the lower part of the plenum...and I'll have some "spacers" made extra so I can "play" with the lengths of the runners and see the results on the dyno/street.
Ok mate. What's the rest of the engine spec?Will post it all together with the dyno results when it's made and tested out properly.
Catcams 5504402Ok mate. What's the rest of the engine spec?
You got a red 197?Catcams 5504402
V6 Ph2 airbox & K&N panel filter
R3 modified front carbon intake
Matched & ported inlet manifold with HDPE gasket
64mm throttle body
Aluminium 520g lightweight crank pulley
Y-pipe, Miltek decat & catback exhaust
remap
On 197/200.net?Yes. Why? :wink:
Thought I recognised your user name!Yes.
This is my car.
What's wrong with your injector angle? It shold be arround 30deg comp. to runners. This is one of the worst designs I have seen so far... Outrageous!
