Sirs, Maams, Ladies and Gentleman.
I've started talks with quite a well known manufacturer (in the JDM scene anyway) of both inlet and exhaust manifolds in regards to an uprated inlet manifold for the 172/182.
The design will be of a similar vein to the RS2 manifold however, the price will be lower due to it being manufactured from aluminium.
There previous projects have included some very heavily boosted drag cars so there kit is more than happy with taking a beating.
Ideas spinning around so far; The manifold will be a one piece design, a welded affair with inbuilt velocity stacks to further increase flow.
An affordable price tag, bear in mind a full race spec inlet which they already manufacture for another engine is currently sitting at just under £700. That's with a lifetime warranty, inbuilt velocity stacks and the option to have additional vacuum points you may need if you decided to have a go with a turbo.
Is there anything you guys would like to see?
On a side note, who would be interested in one, if the price was right?
I've used there kit before, including a full ramhorn manifold which was custom made to my spec with great success.
I'll keep you guys in the loop with regards to the current discussion.
Thanks a lot, Craig.
(I WILL NOT BE THE DISTRIBUTOR FOR THE FINAL PRODUCT)
